KestutisD
Sep 10, 2024Aspirant
Yamaha DM7 and Netgear AV
Hello to all. I have some problem with Yamaha DM7 and Rios's in shared Dante network with other devices. Everything looks fine except Yamaha's dante devices rack mount. All devices are showed in Virt...
LaurentMa
Sep 10, 2024NETGEAR Expert
Hello KestutisD ,
Sorry for the short reply, please do the following, and if no success, please come to us sending an email at [email protected].
Please use the Audio Dante template on VLAN1, or the Audio Dante Profile on the VLAN where all the Dante is connected. It is possible that on the ports connecting to the Yamaha devices, we need to do two things:
1/ Disable STP Mode on these ports
2/ Disable Broadcast Storm Control on these ports
You can easily these two things directly in the table \Configure\Port Configuration in the AV User Interface (AV UI).
If you don't see the table (like an excel spreadsheet) there, please upgrade the switch to the latest firmware here: https://www.netgear.com/support/product/m4250/#download
After changing these two parameters in the table for each port connecting to Yamaha faulty devices, please apply. If successful, then please save the configuration on the upper right!
Thank you,
KestutisD
Sep 11, 2024Aspirant
Hi LaurentMa,
Thank you very much for your help, unfortunately this doesn't help at this time. But what I didn't mentioned above, in my setup I have three AV 4250 switches, one main and two slaves. They're connected by fiber. Today I have found, that when I'm unplugging slave switches - Yamaha starts working. (All Yamaha devices are plugged in to main switch). Maybe I need some special configuration between switches? At the moment all they are in auto trunk mode. One more time, everything works fine from all switches except Yamaha's device rack control for Rio's. (they are in virtual mode when plugged through switch).
Thank you very much for your help.
- LaurentMaSep 11, 2024NETGEAR ExpertThank you. The problem can come from multiple factors (unsupported fiber modules, misconfiguration, etc )
We will need the tech support file out of each switch (AV UI Diagnostics/Support Diagnostics) and an email to [email protected]
Better, you can onboard the switches into the Engage controller (free download at www.netgear.com/Engage) and there is a support tab providing the tech support files of all switches at once.
Please email the team, and one Engineer will get back to you with the solution
