unimorpheus
Dec 12, 2016Aspirant
16 port version of GS108Tv2
This has probably been asked before but I would really like to see a 16 port version of the GS108Tv2. I have the closest equivalent GS116Ev2 but it is not on the same level as the Tv2. It seems the 1...
- Jan 04, 2017
After looking a little deeper it seams the GS116Tv2 I wanted is actually a GS716Tv3 which I ended up purchasing. A bit bigger than I wanted and the deployment in the space available took some thinking but in the end I made it work. Big improvment over the GS116Ev2 that it replaced. The GS116Ev2 was not up to the task of being a backbone switch and would lock out the web GUI under load. GS716Tv3 being fanless was just what I needed.
JohnRo
Dec 13, 2016NETGEAR Employee Retired
Hello unimorpheus,
Welcome to the community!
I have not seen any reports regarding this, but it appears to be a good Idea. You can post this request on the Idea Exchange board. Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.If it gets enough request it might be considered.
Thanks,
