unimorpheus
Dec 12, 2016Aspirant
16 port version of GS108Tv2
This has probably been asked before but I would really like to see a 16 port version of the GS108Tv2. I have the closest equivalent GS116Ev2 but it is not on the same level as the Tv2. It seems the 1...
- Jan 04, 2017
After looking a little deeper it seams the GS116Tv2 I wanted is actually a GS716Tv3 which I ended up purchasing. A bit bigger than I wanted and the deployment in the space available took some thinking but in the end I made it work. Big improvment over the GS116Ev2 that it replaced. The GS116Ev2 was not up to the task of being a backbone switch and would lock out the web GUI under load. GS716Tv3 being fanless was just what I needed.
JohnRo
Dec 19, 2016NETGEAR Employee Retired
Hi unimorpheus,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
