tessus
Jul 09, 2022Guide
after upgrading GS324T to 1.0.0.41 I can't login anymore
I upgraded the firmware of my GS324T to 1.0.0.41 (from the previous 1.0.0.38), but now I can't login anymore.
I always get the message Login failure.
The strange thing is that the switch seems to be running ok, since I can reach all my VLANs.
Thus I thought maybe the firmware upgrade reset the password (since the upgrade fixes a few security vulnerabilities), but I tried all of Netgear's standard passwords, but to no avail.
Any idea what might be going on?
Nothing the like. Since some much earlier firmware releases from about 2019 there was just changing the default password was enforced. However, you had ben able to login before for the update.
Tried to use the [log in] button instead pf pressing the <enter> key?
- tessusGuide
Thanks for your reply. Yes, I tried the login button, but I did not try the enter key.
I am currently locked out and I have to wait 5 minutes.... I'll let you know then.
- tessusGuide
Nope, the <enter> key does not work either. I am really puzzled by this. Never had any issues like this one.
Thank you for trying. The issue I had in mind was more the other way round.
Dropping the browser cache might help, too.
What browser make and version, what base OS?
- tessusGuide
I have now tried another browser (Chrome) and 2 other operating systems. I have also tried from the management network (VLAN1) but I still get the same error message.
I have to say that my trust in Netgear just went down quite a bit. If I can't be sure that a firmware upgrade won't destroy my switch, I'd have to buy the same equipment twice and run tests which should have been run by Netgear in the first place.
I hope that someone from Netgear reads this and provides a solution. How do I get access to my switch again?
- tessusGuide
The only theory I have right now is that the password was hashed as md5 in 1.0.0.38. In 1.0.0.41 the password is hashed with SHA1/SHA2 or whatever (without fallback), and thus can't read the md5 hash and verification fails.
This is the only logical explanation for what is happening. But without access to the source code or a signal from the firmware devs, I am out of luck. I suspect I will have to do a factory reset. However, if I am correct about the password hash problem, I will never be able to upgrade to 1.0.0.41.
Somebody really has to look into this.
schumaku you seem to have contacts at Netgear. Please ping them about this issue.
Already informed Netgear. Was not difficult as you have done everything I could consider, too - great job!
To avoid a worst case scenario, if you are not in a hurry for the switch login, I would wait with the factory reset. Otherwise it would be difficult to restore the backup or reconfigure the switch.
- tessusGuide
Thanks for pinging Netgear.
I can wait. Currently I don't have to make changes to my VLANs or other parts of the network. It just makes me nervous that I cannot login. It feels weird being locked out from my own hardware.
Just to clarify your last sentence. I do have a backup from right before I upgraded. So after a factory reset, I'd only have to boot into image 1.0.0.38 and restore the backup. That would give me access to my switch and it would be correctly configured. Or am I missing something?
Still I think there should be an endpoint I could hit (without having to login) to activate the other image upon next reboot.
If I had a second device, I could run additional tests, but I am afraid I need my network up and running.... Maybe I should buy a second one anyway. If the HW fails, my network would be down until I get a new switch. Such a scenario is unacceptable in my book. It's just that the price of this switch went up by CAD$ 120, which is a lot considering I paid CAD$ 200. But what are $120 compared to a broken network.....
