unchewable
Mar 19, 2018Aspirant
anyone had issues with latest firmware .40
I am moving from 3com dummy switchs to 3 JGS524Ev2 switch's all had the older 2.0.1.26 firmware. I had windows 10 stations that were not able to use microsoft apps or update after moving most everyth...
- Mar 19, 2018
Hi unchewable,
Welcome to Netgear Community!
You do not need to reverse back to the older firmware, use the latest version 2.0.1.40.
JGS524Ev2 works with Category 5e (Cat 5e) or better Ethernet cable.
NETGEAR Employee.
ElaineP
Mar 20, 2018NETGEAR Expert
Hi unchewable,
Please avoid forming loops for network environment. If you see all ports LED blink quickly, and you cannot login the switch, maybe loop happens.
If your concern has been resolved, please mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
NETGEAR Employee.
unchewable
Mar 20, 2018Aspirant
Yeah the really strange thing was without changing any of the hardware except the firmware change I wasn't able to navigate to the switch via chrome but I could with IE that is what threw me. I am glad I found that loop it has probably been there for years as it was installed by someone else.
