davidcts
Apr 29, 2025Aspirant
Auto Voice VLAN setup
We are looking to isolate our VoIP traffic to its own VLAN. For a number of reasons, we'd like this to happen without needing to configure each phone. It looks like Netgear switches support this. ...
davidcts
- schumakuApr 30, 2025Guru - Experienced User
Hello davidcts
Have no recent practical experience with that S3300 switch series.
What looks right to me is that the Auto-VoIP VLAN is set to the VLAN ID 88.
But then, strange is that the VLAN 88 does show up as a VLAN-Type: Static
and
the VLAN-Membership for VLAN 88 is set manually to [U]ntagged
and
the Voice-VLAN-Configuration does show Operational State: Disabled
This makes me believe you have -manually- defined the VLAN 88 on top of the Voice-VLAN, manually assigning port 1/g-1 ... 1/g-52 (you don't have to do this in my understanding!) on top of what should be part of the Voice-VLAN-Config automatically once enabled.
So, remove the VLAN 88 port assignments -and- the manually define VLAN 88.
- davidctsApr 30, 2025Aspirant
I removed the manually created VLAN 88 from Switching > VLAN > Advanced > VLAN Configuration, which automatically removed any options for it from VLAN Membership.
However, I do not see any way to set the Operational State to Enabled, as displayed under Switching > VLAN > Advanced > Voice VLAN Configuration. When checking Switching > Auto-VoIP > Protocol-based > Port Settings, all ports show Auto VoIP Mode as Enabled.
Something still isn't correct; the phones aren't being pushed over to VLAN 88.
- schumakuMay 01, 2025Guru - Experienced User
Auto-VoIP Global Admin Mode enabled?
Voice-VLAN Interface(s) Interface Mode set to VLAN-ID, and the Value set to 88?
