davidcts
Apr 29, 2025Aspirant
Auto Voice VLAN setup
We are looking to isolate our VoIP traffic to its own VLAN. For a number of reasons, we'd like this to happen without needing to configure each phone. It looks like Netgear switches support this. ...
schumaku
May 01, 2025Guru - Experienced User
davidcts wrote:
However, I do not see any way to set the Operational State to Enabled, as displayed under Switching > VLAN > Advanced > Voice VLAN Configuration. When checking Switching > Auto-VoIP > Protocol-based > Port Settings, all ports show Auto VoIP Mode as Enabled.
Something still isn't correct; the phones aren't being pushed over to VLAN 88.
Auto-VoIP Global Admin Mode enabled?
Voice-VLAN Interface(s) Interface Mode set to VLAN-ID, and the Value set to 88?
davidcts
May 01, 2025Aspirant
Your tips brought me a big step closer. The Global Admin setting had no impact, but once I set the Interface Mode to VLAN-ID, our phones are registering on VLAN 88.
Unfortunately, our FortiGate routers are not playing well with this configuration. I've got a pair of HA routers in an active/passive setup using ports 45-48.
- Ports 47-48 are running default VLAN on both the switch and routers. This is fine, and dishes out DHCP leases to everything else on default VLAN.
- Ports 45-46 are plugged into the routers on a different ports assigned to a separate LAN (different subnet, etc). The routers have that LAN set to use VLAN 88. But, the switch and routers do no seem to be playing nicely together, and a phone plugged in will not find any DHCP server. So, the phones are completely non-functional in the current configuration.
I've tried to adjust as follows:
- My go-to idea at this point was to alter the MAC address for the VoIP LAN. Unfortunately, FortiGate does not allow this.
- My next idea was to re-input the VLAN under Switching > VLAN > Basic > VLAN Configuration, and then set ports 45-46 to PVID 88 under Switching > VLAN > Advanced > Port PVID Configuration. This doesn't seem to have made any difference.
- My next idea was to manually tag ports 45-46. However, the switch recognizes that VLAN 88 is for Auto-VoIP, and is not allowing me to manually set ports 45-46 as Tagged.
So... how do I get the Netgear switch to play nicely with the FortiGate routers?
Thanks again!
- schumakuMay 02, 2025Guru - Experienced User
Do the two (or more?) physical HA ports of the have dedicated MAC addresses? Most likely: Yes! So add these MAC address OID part to the OUI table, and add these ports to the Auto-VLAN config. That's about it.
- davidctsMay 02, 2025Aspirant
I considered that. However, in an active/passive HA configuration, they create a "virtual" MAC address that is different from their physical/permanent MAC addresses. When I check the ARP table in the switch, it only knows the shared virtual MAC address, which FortiGate products do not allow to be changed. If I could target the entire virtual MAC address, that could work... but the prefix is shared by the primary/default LAN.
No rocket science, guess they use VRRP with a well known base MAC plus a group number or something the like.
