aimnano
Jan 31, 2016Aspirant
Automatic Configuration Backup
I have tons of Smart switches deployed, many of which have complex VLAN configurations. I'm wondering if there is any way to backup the configs besides me logging via web browser and manually downlo...
- Jan 31, 2016
Hi aimnano,
Welcome to the community! :)
You may want to try the NMS300. It is a Network Management System Software that might help you backup the configurations of your devices. Kindly check the NMS300 data sheet here and check if that NETGEAR Smart switches and other NETGEAR devices you have is compatible with it.
Kindly access this link as well for more information.
DaneA
NETGEAR Community Team
DaneA
Jan 31, 2016NETGEAR Employee Retired
Hi aimnano,
DaneA
- aimnanoJan 31, 2016Aspirant
Is there any place to get more assistance with NMS?
I don't seem to be able to 'discover' 3rd party devices, failing with "Credential Failure" (despite having correct port + credentials).
And even with the NetGear switches that have been discovered, if I attempt to execute a backup job on one, I get an error "No valid HTTP/HTTPS credential."
