ARAMP1
May 22, 2018Aspirant
Best Utility for my Switches (ProSafe GS750E and ProSafe GS728TP)
I've been using a 28 port POE ProSafe GS728TP for some time for my home network and it has worked well for me until I needed more ports. I came across a deal on a ProSafe GS750E and added the much n...
- May 23, 2018
Hi ARAMP1,
Welcome to the community! :)
Anyway, is there a single control utility for both switches?
There is no single utility that would work on both GS750E and GS728TP switches.
The GS750E switch belongs to the category of the Smart Manage Plus Switches of NETGEAR. Only the ProSAFE Plus Configuration Utility will work for all Smart Manage Plus Switches.
The GS728TP switch belongs to the category of the Smart Manage Pro Switches of NETGEAR. Only the Smart Control Center Utility will work for all Smart Manage Pro Switches.
However, you can manage both GS750E and GS728TP switches via its web-based GUI. Open two tabs on a browser (such as Firefox or Chrome) then enter the corresponding IP addresses of the GS750E and GS728TP switches respectively. To login, the default username and password are 'admin' and 'password' without the quotation marks.
DaneANETGEAR Community Team
DaneA
Jun 03, 2018NETGEAR Employee Retired
Just want to follow-up on this. Let us know if you have further inquiries.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
ARAMP1
Jun 03, 2018Aspirant
DaneA,
Truly appriciate the quick reply. Thanks!
