RussU
Mar 20, 2016Aspirant
Blocking IP range/subnet with ACL
I can only assume I'm missing something here... I want to block access to one VLAN from another whilst maintaining routing via the switch. Simple enough on the face of it.
I have set an IP ACL bound to the VLAN in question to block IP traffic to 192.168.0.0 255.255.255.0 but it does nothing. If I set the IP to 192.168.0.10 255.255.255.0 then I cannot ping the device on that IP, so the rest of my config should be fine.
Am I doing something wrong, or is this just not supported on this switch?
Firmware is updated to 6.3.1.11
Hi RussU,
Welcome to the community! :)
Kindly check this link as a reference guide in setting up ACL.
DaneA
NETGEAR Community Team
