mwsealbeach's avatar
mwsealbeach
Follower
Apr 26, 2018
Can I connect a GS752TXS switch to a Dell S4128F switch with a 10Gb SFP+ cable?
I have several GS752TXS(SW 5.2.0.26) switches and they are working great. My new Nutanix cluster is running on 2 Dell S4128F switches (these are all 10Gb SFP+ ports, no RJ45 connections). Before I st...
  • LaurentMa's avatar
    Apr 26, 2018
    Hi mwsealbeach
    Thank you for your message. That should be no problem, assuming you are using the other switch vendor DAC cables, we should accomodate them just fine. If not, we'll want to test with NETGEAR DAC cables instead. But I don't expect any issue here.
    Hope this helps!
ProSupport for Business
