FastBlader
Jan 04, 2019Aspirant
Cannot update firmware or IP address or DHCP
I'm using ProSAFE Plus Configuration Utility 2.7.2 on Win7 to update my GS108Ev2 switch running 1.00.04 to 1.00.12. The switch shows IP Address 192.168.0.239 and Located on IP Network is 10.1.10.19...
- Jan 04, 2019
Temporary configure your computer into the 192.168.0.0/24 network, any address different from the default switch .239 or the .255 (broadcast) and retry.
schumaku
Jan 04, 2019Guru - Experienced User
- FastBladerJan 09, 2019Aspirant
I did not think of that. Worked great! Thanks for the tip.
