ddejarnett
Mar 05, 2019Tutor
Can't Access Admin Interface over LAG on XS716E
I have a XS716E 16 Port 10-Gigabit Ethernet Smart Managed Plus Switch with a 6 port LAG configured that is connected to a Cisco trunk. From a node on the Cisco, I can't access the admin interface of...
- Mar 05, 2019
Have no more XS708Ev1/XS708Ev2XS716E in operation. Vaguley remember having had the very same problem on one or some of these models initially, however it was fixed with some firmware update later on. Must admit never had that many ports in a LAG, but up to two resp. four ports in a static LAG.
Is the firmware updated to the current version from https://www.netgear.com/support/product/XS716E#download ?
ddejarnett
Mar 05, 2019Tutor
Traffic gets passed perfectly over the trunk/LAG. (on all VLANs) I just can't connect into the web ui without being on a device connected directly to that switch.
schumaku
Mar 05, 2019Guru - Experienced User
- ddejarnettMar 05, 2019Tutor
No it's not - I found that a few hours ago. I'm going to update it later tonight and see what happens.
Thank you for pushing me in the right direction. Firmware was the problem. I updated it and now I can access the Web UI from the LAG.
