awraynor's avatar
awraynor
Can't access JGS524Ev2 via ProSafe Pluis Configuration Utility
Replaced my GS108 with a JGS524Ev2 24-port switch. Everything is working with just plug-and-play.   I've installed the ProSafe Utility on two different Windows 10 machines. On both I can see the sw...
  • DaneA's avatar
    Aug 31, 2016
    Hi awraynor,
    Welcome to the community! :)
    Try the steps below:
    a. Try to disconnect the JGS524Ev2 switch from the existing network.
    b. Connect a PC/laptop directly to any LAN port of the JGS524Ev2 switch.
    c. Set a static IP address of 192.168.0.x (x can be any number) on the PC/laptop.
    Note: The default IP address of the JGS524Ev2 is 192.168.0.239.
    d. Open the ProSAFE Plus Configuration Utility and try to access the JGS524Ev2 switch.
    If necessary, perform a factory reset on the JGS524Ev2 switch then repeat the steps above.
    DaneA
    NETGEAR Community Team
