arrialive's avatar
arrialive
Can't change untagged VLAN on GS752TP with 6.0.1.18 Firmware
I have 2 GS752TP Switches in the office, switch #1 is running 6.0.1.18 switch #2 is running 6.0.1.16.   I have the 3 default VLANs on each switch, and then 8 additional VLANs that I'd added.   Wi...
  • arrialive's avatar
    Jun 16, 2017
    Ah, foud it.
    It appears that on the 6.0.1.18 version of the firmware to change the Untagged VLAN membership on the Netgear switch you need to go to the Port PVID Configutation and set the PVID to the Untagged VLAN you want. That will clear the Untagged setting from VLAN 1 on the VLAN Membership configuration, then you can set the VLAN you want as Untagged on the VLAN Membership configuration.
ProSupport for Business
