mambojuice
Sep 21, 2016Aspirant
Can't manage JGS524Ev2 from another subnet
Is the JGS524Ev2 locked down to only allow web management from the local subnet? I used the ProSafe Plus utility to search for and detect my new switch from a computer with a 192.168.1.0/24 addre...
- Sep 30, 2016
Finally had a chance to use Wireshark, any connections from the 192.168.1.0 network were being refused.
I ended up reinstalling the firmware even though it was the same version and then doing a factory reset and reconfiguring everything. Now it is accessable.
Very strange :-/
Napsterbater
Sep 23, 2016Apprentice
Does said switch have a correct default gateway/route set?
mambojuice
Sep 26, 2016Aspirant
Yes, both switches have the same gateway 192.168.3.1
There is no firewall or ACL defined controlling traffic flow between subnets, they are separated purely to differentiate services (users, storage, management)
- NapsterbaterSep 26, 2016Apprentice
Start looking at the Router/Gateway for the 192.168.1.0/24 Network, or snif the traffic on the switch port, see if its even hitting the switch. My money is on the rotuter/gateway..
- mambojuiceSep 30, 2016Aspirant
Very strange :-/
