bootlake
Aug 07, 2018Aspirant
computer must be connected directly to ARRIS router and also, NeGS116v2 at same time (work around?)
Computer
Operating System
Processor
Graphics
Networking and I/O
Memory
- DaneANETGEAR Employee Retired
Hi bootlake,
Welcome to the community! :)
Does the Arris router provide wireless network? If yes, then you can connect the Windows 10 PC wirelessly to the wireless network being broadcast by the Arris router and at the same time, connect the ethernet port of the Windows 10 PC directly to the GS116v2 switch.
If the Arris router and the GS116v2 switch are both within the same LAN, then the typical setup should be: modem--Arris router--GS116v2--PCs. The GS116v2 is just a pass through, unmanaged switch wherein its purpose is to extend the local network so that you can connect more devices to the LAN such as printer and PCs.
DaneA
NETGEAR Community Team
- bootlakeAspirant
Thanks Dane for responding.
Both do provide wireless access. The problem is that I hibernate or shut down the computer (to save energy). That would shut off the wireless connection.
Of course the wireless link will go down if the computer does hibernate and certainly once shut-down.
The switch is not involved in the wireless connection - this is not a Netgear issue.Worth a note: Decent Windows does prefer the wired connection over the wireless if both are connecting into the same network, however this does not prohibit the computer from re-establishing the wireless connection. Have seen several posts here in the community where users report a similar problem (more macOS, few Windows) with some Netgear wireless routers where users report that the wireless connection is not re-established after sleep or hibernation.
