tantony
Oct 04, 2018Luminary
Connecting Junper firewall to NetGear ProSafe XS716T switch
I have a Juniper SRX550 Firewall configured to handle network and DHCP. I have the cable from Juniper going into port 1 on the NetGear switch. Which VLAN does port 1 needs to be on the switch?
- Oct 04, 2018
It turns out, it was Symantec causing the ping not to work. My laptop have Symantec, and the other laptop doesn't. I switched cables, and I'm not able to ping my laptop, but the other laptop I can.
DaneA
Oct 04, 2018NETGEAR Employee Retired
It is possible that the ping is reaching the laptop but sending ping replies is not enabled to it . Let me share the article below and it might help:
Configure the Windows firewall to allow pings
How to Enable Ping Response in Windows 7/8.1/Vista Firewall? How to Block Too
DaneA
NETGEAR Community Team
tantony
- schumakuOct 04, 2018Guru - Experienced User
Typical Internet Security garbage. Not much added value, poorly integrated with WIndows, and a common source of issues. The best button is the [Uninstall].
