DruidJon
May 17, 2016Aspirant
Connecting two GS724Tv3 switches together via fibre
Hi everyone, I've never been to this forum before so please bare with me! Owing to distance (greater than 100m less than 175m) I would like to connect (cascade) 2 GS724Tv3 switches together v...
- May 23, 2016
Hi DruidJon,
As a follow-up, you may refer to the table below:
DaneA
NETGEAR Community Team
JohnRo
May 18, 2016NETGEAR Employee Retired
Hello DuidJon,
Welcome to the community!
We recommend using our SPF GBIC Modules (AGM731F and AGM732F). For that distance (175 max) the "short-reach" module (AGM731F) should be fine since using a 62.5/125ìm OM1 multimode fiber cable can drive gigabit ethernet up to 275 m. For the termination, you'll probably need some expert advice for that since these are only sold as SFP modules only (unterminated). For question number 4, yes it should be since using regular ethernet will not be able to handle the distance.
For more information, please click here.
Thanks,
