pmkrautle
Dec 14, 2018Aspirant
CRC errors upgrading GS724TP Firmware
We received a new GS724TPV2 switch - the boot release is at B1.0.0.2 and firmware software version is 1.1.1.3 - we'd like to update the firmware before installing at the customer site.
This pro...
- Dec 16, 2018
Hi pmkrautle,
Welcome to the community! :)
This article you have posted is for the GS724TP (or GS724TPv1). The switch that you have is a GS724TPv2 (v = version). The firmware versions of the GS724TP is not compatible with GS724TPv2 and vice versa.
You may upgrade the firmware of your GS724TPv2 switch from v1.1.1.3 to the latest version which is v1.1.1.25. You can download firmware v1.1.1.25 here. Be reminded to perform a factory reset on the GS724TPv2 switch after upgrading the firmware then reconfigure the setting from scratch in order to start clean using the latest firmware version.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Dec 16, 2018NETGEAR Employee Retired
Hi pmkrautle,
DaneA
pmkrautle
Dec 22, 2018Aspirant
This worked - many thanks for the guidance.
Peter
