Chillies777
May 28, 2017Aspirant
Custom limiter
Hey Netgear Fundi's ;) I trust this finds everyone well. I would like to know if Netgear are able to allow for a custom "set by yourself" speed limiter, instead of having, a drop down list to...
- Jun 02, 2017
Hi Chillies777
Short answer, yes.
For instance, using M4100-D12G (GSM5212-100NES ordering SKU), you can set up simple ACL for all traffic with global rate limit and assign this rule to any port. Web interface (GUI) is fully functional, and more intuitive than command line (telnet or SSH).
Best,
LaurentMa
May 30, 2017NETGEAR Expert
Thank you, XavierLL!
Also available in Managed Switches GUI (web interface) for standard and advanced ACLs
For instance with M4300 series, see page 599 in GUI User Manual for advanced ACL with single data rate and burst size, or page 591 for basic ACL. ACLs can be binded to physical interfaces (ports) or VLANs.
Chillies777
May 30, 2017Aspirant
Hi Gents,
Thank you to both for your answers.
The Netgear language I heard you guys speak and mention in the previous comments is higher talk to me. I'm into simpler networks and on the rookier side of things and learing.
So I suppose the managed switches can maunally be custom set on a simpler manner via the GUI?
Many thanks for such positive response from Netgear!
Charles
- LaurentMaJun 02, 2017NETGEAR Expert
Hi Chillies777
Short answer, yes.
Best,
- Chillies777Jun 02, 2017Aspirant
Hi LaurentMa,
Thank you so much for getting back to me in such simple and professional manner, only an honour dealing with you and the service you have delivered.
Regards
Charles
- Nov 30, 2019Retired_Member
