MikeH701's avatar
MikeH701
Dead ProSAFE Plus 24 Port Switch with PoE (JGS524PE)
This switch stopped working and has a limited lifetime warranty but when I try to open a support case it says, "The chat queue is busy right now. Try again soon." What good does it do to have this if Netgear blocks your ability to use the lifetime hardware warranty??? What do I do?
  • kohdee's avatar
    kohdee
    Mar 17, 2022
    Hi MikeH701,
    I'll refer your account to our support team to reach out and help with your RMA.
    Sorry for the inconvenience.
    -kohdee
  • Hi, I have the same issue.
  • schumaku's avatar
    schumaku
    On https://my.netgear.com/ -> MyNETGEAR -> My Registered Products - on this list, click on the registered device, and follow the [Request a Hardware Replacement]. With the RMA number available, you should get a phone number to call ...
    • MikeH701's avatar
      MikeH701
      Phone support is not an option. Chat is the only option.
      • schumaku's avatar
        schumaku
        Use the [Request a Hardware Replacement] (left side) - and not contact support by chat or the like (as shown to the right) - then you get this:
ProSupport for Business
