Arnaud_D
Dec 08, 2017Aspirant
DHCP Snooping Block DNS Packet
Hi, I've just encounter an issue with my GS724TPv2. As soon as I enabled the DHCP Snooping mode, I cant make dns resolving. Trusted Inferfaces are ok, and I retrieve an Ip from my dhcp server (w...
- May 11, 2018
Hi, that happened to me, what I did to solve the problem was to install the firmware
more recent, since the firmware 1.0.0.24 that brought that switch is the cause of the problem.
DaneA
Dec 10, 2017NETGEAR Employee Retired
Hi Arnaud_D,
As far as I have checked, there is no issue logged for the GS724TPv2 as per described in your initial post. Let us try to reflash the firmware. Here are the steps below:
1. Download firmware v1.1.0.24 from this link to your PC. Make sure to unzip it and save it to your desktop screen.
2. Disconnect your GS724TPv2 from your existing network.
3. Connect the same PC where you have downloaded firmware v1.1.0.24 to a LAN port of the GS724TPv2. Set a static IP address of 192.168.0.210 to your PC.
4. Open a browser like IE or Firefox then at the address bar, type 192.168.0.239 then press Enter. Login to the user interface of switch. Enter "admin" as the username and "password" as the password.
Note: The default IP address of GS724TPv2 is 192.168.0.239.
5. On the web-GUI, go to Maintenance > Download > HTTP File Download.
6. On File Type, select Archive. On Image Name, select image2.
7. Click Browse then locate the firmware v1.1.0.24 that you have unzipped earlier.
8. Click Apply.
Note: After a file transfer is started, please wait until the page refreshes. When the page refreshes, the Select File option will be blanked out. This indicates that the upgrade process is done.
9. On the web-GUI, go to Maintenance > File Management > Dual Image Configuration.
10. On the image name, select image2 then check the box that says "Activate Image" and click Apply.
11. On the web-GUI, go to Maintenance > Reset > Factory Default.
12. Check the box then click Apply. Wait for the GS724TPv2 to boot up by itself.
Note: It is recommended to reset the device back to factory default settings after doing a firmware upgrade/downgrade.
13. On the web-GUI, go to Maintenance > File Management > Dual Image > Dual Image Status. make sure that image2 is the "current-active" image.
14. Reconfigure the settings from scratch in order to start clean using the firmware uploaded. Observe if same problem occurs.
DaneA
NETGEAR Community Team
- Arnaud_DDec 11, 2017Aspirant
Hi DaneA,
I did as you said :
-DL the firmware
-Factory reset
-Flash the firmware
-I tried to import my previous configuration > same error
-Factory reset N°2
-Minimalist configuration (2 vlans, switch ip, dhcp snooping on/off) > The same problem occurs, as I enable the dhcp filtering > no dns traffic
The 3 GS724TP are new, first configurations testing last week.
Thx for any further advice
- HopchenDec 11, 2017Prodigy
Hi Arnaud_D
Thanks for trying the suggestions by DaneA. It is always good be on latest FW, etc.
You still have the problem I can see. This is of course not normal behaviour for DHCP snooping. I would like to try and replicate the issue in the lab, today. I will keep you posted.
Cheers!
