danielnello
Jul 09, 2025Tutor
Discovery Tool - no network options in drop down
I am trying to use the NETGEAR Discovery Tool on a relatively fresh installation of Windows 11 Pro. I have confirmed that sharing and network discovery are enabled on the computer, but don't know whe...
Wilsodg
Jul 24, 2025Guide
I have exactly the same issue. I turned off firewall protection (ESET). I am on private network with network discovery enabled. The ProSafe Plus utility works and finds switches (it would not work on my Windows 10 pc but does on the Win 11). At a loss to know what else to try.
