MLandowski
Apr 25, 2019Aspirant
Energy Efficient Ethernet support at 2,5/5 GbE
With devices from competing vendors we ran into an issue where Energy Efficient Ethernet would work only at 1 Gbps link speed, even though switch supported higher speeds. Do Netgear switches have a s...
- Apr 25, 2019
MLandowski wrote:
With devices from competing vendors we ran into an issue where Energy Efficient Ethernet would work only at 1 Gbps link speed, even though switch supported higher speeds. Do Netgear switches have a similar limitation?
Provide more information about the use case, the test, and the effects you have seen with the competitor devices (detals like make/model are always interesting).
The XS728EM online help says:
EEE - Combines the Energy Efficient Ethernet (EEE) 802.3 MAC sublayer with the 100BASE-TX, 1000BASE-T, 2.5GBASE-T, 5GBASE-T and 10GBASE-T physical layers to support operation in Low Power Idle (LPI) mode. When LPI mode is enabled, systems on both sides of the link can disable portions of their functionality and save power during periods of low link utilization.
===We have EEE enabled on the XS724EM, and haven't spotted any negative impact. Switch-to-switch connections with LAGs on 10 GbE links, NAS with dual 10 GbE LAG, and clients on 2.5G or 5G.
Trouble is that the Smart Managed Plus have very limited management and monitoring capabilities - it might be hard to see and proof that the ports are entering the LPI mode.
schumaku
Apr 25, 2019Guru - Experienced User
- MLandowskiApr 29, 2019Aspirant
Thanks for the reply. Unfortunately company I work for has very strict secrecy policies, so I'm not able to discuss full scenario, but it's mostly about compliance. Looks like XS724EM indeed supports EEE at 5G, so it should be ok for us, I should be be able to verify it on the endpoint side.
