ldreser
Mar 12, 2018Aspirant
Expanding the XS728T Switch
Hello all, This is probably bit of a beginner question, however we are running the Smart Managed 24 Port XS728T Switch and since we're out of 10Gbe ports, we need to expand. I refered to ...
- Mar 14, 2018
ldreserwrote:If we wanted to expand the XS728T and have 10g ports, why aren't we able to just buy another XS728T and connect them via SFP+ ?
Is that not possible ?
Hello Lukas,
Yes, of course this is possible. You can (for example) use two XS728T and establish a trunk connection using 2..4 SFP+ based connections. The most affordable way is using 10G DAC cables like the Netgear AXC763 (or compatible) available in 1m and 3m length when set-up the devices side-by-side. Set-up multiple trunk ports in a 802.3ad LACP LAG, and use tagged VLANs of course.
The difference when using a stacked system is that you can maintain one logical switch, while the administration on multiple Smart Managed Pro switches is done per switch.
-Kurt
ldreser
Mar 13, 2018Aspirant
Hi Eric,
Thank you for your reply, I am still a bit confused. I understand that the S3300 supports 10g uplinks as a connection between the stack, however it only has 1g ports.
Thanks again,
Lukas
schumaku
Mar 14, 2018Guru - Experienced User
Hello Lukas,
-Kurt
