AMal
Mar 19, 2017Aspirant
Extending PoE using a GS105PE switch
I have an IP birdbox camera on one end of a 40m cat5E cable with a PoE injector at the other end. I would like to add another IP camera near the first one. The PoE injector has a label saying 48 vol...
- Mar 23, 2017
Hi DaneA,
I just received this morning a GS105PE switch and a 30W 802.3at/af PoE Injector, and I am convinced that this will be a good solution.
Thanks for your help.
Alan
DaneA
Mar 23, 2017NETGEAR Employee Retired
AMal,
I just want to follow-up on this. Let us know if you have further questions. :)
Otherwise, if ever your concern has been addressed, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
AMal
Mar 23, 2017Aspirant
Hi DaneA,
Alan
- Feb 22, 2022Retired_Member
