chrisp08
Nov 10, 2020Initiate
Firmware Error? QoS Rate Limit
Hi, I just set the OoS Rate Limit Ingress Rate to 32 Mbps and the Egress Rate to 8 Mbps. When I downloaded a larger file via WeTransfer, I noticed that both Upload and Download are reduced to 8 Mbps...
- Dec 03, 2020
chrisp08 wrote:I just set the OoS Rate Limit Ingress Rate to 32 Mbps and the Egress Rate to 8 Mbps. When I downloaded a larger file via WeTransfer, I noticed that both Upload and Download are reduced to 8 Mbps.
Perfectly correct - typical chair-keyboard issue.
Think again....
According to the screeenshot, you have all ports rate limited ...
SpoilerThere are _two_ ports participating in the data path!
Upload: The egress rate on the port to the Internet/router is limited to 8 Mb/s.
Download: The egress rate of the port to the computer side is limited to 8 Mb/s.
If you intend to limit the rate to the "computer" ports, only configure a rate limit on the coputer ports, not on the uplink port.
If you intend to limit the rate for all computers on this switch, only configure the rate limit on the uplink port, not on the indvidual computer ports.
schumaku
Dec 03, 2020Guru - Experienced User
Think again....
Spoiler
