robby61
Aug 12, 2015Aspirant
Firmware Update Problem Gs748TS
Hello everybody, I can not run a firmware update because the static IP address can not enter. When I wear these in the form of a 192.168.xxx.xxx, is to apply this reset to 0.1.134.160. If I go thr...
- Aug 25, 2015
Hello ,
the problem is settled.
Have solved it with a TFTP server.
You only have to put the firmware file into a folder alone.
Thank you all
Best regards
Robby
robby61
Aug 25, 2015Aspirant
Hello,
I uploaded the new bootloader with TFTP Server.
Only the firmware it does not accept.
The old version Booloader was 1.0.0.07; new 1.0.2.0 , this ist no theme more
current firmware version of the GS748TS is 3.1.0.1,
upgrade the first 5.0.21 to
the next 5.2.11
The problem is that the switch does not recognize smart Wizzard.
Even the smart control center does not recognize him.
The web access works.
factory reset no success
Reset the device with needle.
robby61
Hello ,
Thank you all
Best regards
Robby
