tbuilt62's avatar
tbuilt62
Firmware upgrades
Can you upgrade firmware from 5.2.0.26 to 6.1.0.36 on Netgear GS752TXS?
  • DaneA's avatar
    DaneA
    Apr 27, 2017
    tbuilt62,
    Kindly answer the questions below:
    a.  Have you tried to clear the cache on the browser you are using?
    b. Have you tried using other browsers like Firefox or Safari?
    c. Have you tried using other PCs or laptops to isolate the problem?
    If your answer is "Yes" from the questions above and still same problem, kindly try the steps below:
    1. On the web-GUI, go to Security >  Access then click on the HTTPS > HTTPS Configuration link.
    2. Make sure to enable HTTPS Admin Mode.
    3. On the HTTPS port field, make sure it is set to 443.
    4. Click Apply then check if you are able to access the web-GUI of the GS752TXS switch via HTTPS.
    5. Try to reboot the GS752TXS switch then try again to access the web-GUI via HTTPS.
    As reference, kindly read pages 203-205 of the GS752TXS Smart Switch Software Administration Manual here
    DaneA
    NETGEAR Community Team
ProSupport for Business
