Edunishi
Feb 08, 2018Aspirant
FS728TPv2 MIB files. Enable/disable POE admin mode via NMS300
Hi, We currently have 50 FS728TPv2 switches and are used to power electronic locks. We would like to know if there is a MIB file for the FS728TPv2 where it would be possible to cut the POE of a s...
- Feb 14, 2018
I just want to follow-up on this. Were you able to download the FS728TPv2 MIBs? If yes, does it include the specific MIB where it would be possible to cut the POE of a specific port via SNMP?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Feb 11, 2018NETGEAR Employee Retired
Hi Edunishi,
Welcome to the community! :)
You can download the FS728TPv2 MIBs on this link. The link will expire within 48 hours. Check if the FS728TPv2 MIBs includes the specific MIB where it would be possible to cut the POE of a specific port via SNMP
DaneA
- DaneAFeb 14, 2018NETGEAR Employee Retired
DaneA
- EdunishiFeb 14, 2018AspirantHi, yes it worked perfectly. Thanks for the help.
