JaapTon
Feb 11, 2015Novice
FS750T2 does not boot, all lights are green
I have 2 used of these switches, both with the same problem: When I put in the powercord all lights of the 48 ports are on (green). Nothing happens when I connect the switch to my modem. Is seem...
- Feb 11, 2015
JaapTon wrote: When I put in the powercord all lights of the 48 ports are on (green).
- If all 48 port LEDs stays lit up green when nothing connected to it, then it seems to be a faulty hardware.JaapTon wrote: Nothing happens when I connect the switch to my modem.
- Be reminded that the switch should not be directly connected to a modem-only device. However, if its a modem-router combo then that is just fine.JaapTon wrote: Is seems that nothing happens when I use the restart button and/or reset to factory settings button.Suddenly (I don't know exactly after what I was doing) I saw a switch in the SmartWizard and only 1 port was green. It looks like the switch was working fine and I installed the latest firmware. All went fine, but after I take off the powercord and put it back again the same problem appaers. Now I can do what I want, nothing seems to help to reboot the switch.
Is there a certain reset procedure to use the reset and/or reset to factory button(s)?
- Try to do a power reset. Here are the steps:
a. Press the factory reset button for 30 seconds while the switch is on.
b. After 30 seconds, turn off the switch for 5 seconds but still continue to press the factory reset button.
c. After 5 seconds, turn on the switch while you continue to press the factory reset button. Wait for another 5 seconds.
d. Release the factory reset button. Check if it will boot up completely.
fordem
Feb 12, 2015Mentor
The ProSafe switch line has a lifetime hardware warranty, I would not hesitate to recommend them to any of my clients.
http://www.netgear.com/business/documents/prosafe-lifetime-warranty/default.aspx
