JaapTon
Feb 11, 2015Novice
FS750T2 does not boot, all lights are green
I have 2 used of these switches, both with the same problem: When I put in the powercord all lights of the 48 ports are on (green). Nothing happens when I connect the switch to my modem. Is seem...
- Feb 11, 2015
JaapTon wrote: When I put in the powercord all lights of the 48 ports are on (green).
- If all 48 port LEDs stays lit up green when nothing connected to it, then it seems to be a faulty hardware.JaapTon wrote: Nothing happens when I connect the switch to my modem.
- Be reminded that the switch should not be directly connected to a modem-only device. However, if its a modem-router combo then that is just fine.JaapTon wrote: Is seems that nothing happens when I use the restart button and/or reset to factory settings button.Suddenly (I don't know exactly after what I was doing) I saw a switch in the SmartWizard and only 1 port was green. It looks like the switch was working fine and I installed the latest firmware. All went fine, but after I take off the powercord and put it back again the same problem appaers. Now I can do what I want, nothing seems to help to reboot the switch.
Is there a certain reset procedure to use the reset and/or reset to factory button(s)?
- Try to do a power reset. Here are the steps:
a. Press the factory reset button for 30 seconds while the switch is on.
b. After 30 seconds, turn off the switch for 5 seconds but still continue to press the factory reset button.
c. After 5 seconds, turn on the switch while you continue to press the factory reset button. Wait for another 5 seconds.
d. Release the factory reset button. Check if it will boot up completely.
Hardhat
Feb 13, 2015Aspirant
You may no longer need any other input on the green lights...
I have a GS724Tv4 which after connection to router only which was already connected to cable modem, green lights galore! I thought I fried it! The 1st LAN cable (1st computer) plugged into the switch after that all the green lights went off and only the router connection and computer connection lit up green, ie 1000 MBps.
Hope you got this resolved already.
