phrogboy264's avatar
phrogboy264
G748T doesn't recognize new computer Hardware
Long time lurker, first time poster.  I didn't see anything posted similar, but have heard of it in passing conversations with other integrators.
We have ProSafe GS748Tv4H2 deployed on our exhibit network (think museum) since 2014.  We've begun the process of updating hardware attached to those switches.  We've found that newer model NICs on the computers we are installing are not recognized by the switch at all.  When we attach the computer to the switch, we get nothing from either LED indicator lights on both ends.  We've factory reset and can't communicate even at default settings.  We've updated firmware to 5.4.2.30.  The only way we can seem to work around is to use USB->ethernet convertors, but then we lose the ability to WOL and some of the other network based automation functions.
Has anyone seen this behavior and knows a remedy?  Are we just going to need to replace all the switches (we did have to get a GS748Tv5 recently and it communicates just fine with new machines).
#gs748Tv4
  • schumaku's avatar
    schumaku
    Long before Geisterbanh on the switch, I suspect your newer (unknown) Ethernet adapters on the older computers (unknown OS) are not properly configured, recognized and loaded with the driver Microcode. In general, Ethernet (10...1000Mb/s) is extremely reliable.
     Are random selected, known working Ethernet adapters, no longer working on the switch (all or in group of eight) ? This would indicate a possible switch issue (or more a failure) then.
    Back to 2016 (GS748Tv4 Firmware Version 5.4.1.17), I have not spotted possible bootloader updates where the potentially forgotten firmware updates lead to a dead switch.
    • phrogboy264's avatar
      phrogboy264
      schumaku
      Thanks for the info.  To provide more detail we aren't seeing any connection activity on new computers that are replacing old computers.  These new machines include but are not limited to new generation NUCs, and custom built rackmount PCs using latest available hardware (Motherboards and Gen 11+ processors).
      We are not seeing complete failure in blocks/groups or even in singular ports.  For example: a port will function/communicate/pass traffic for an old Polywell Mini PC that has an integrated Broadcom NetLink (TM) Gigabit Ethernet adapter (in use since around 2014).  I will move that same cable to a brand new NUC (RNUC11PHKi7C001)
      running an Intel(R) I225-LM and get no activity whatsoever.  If I switch back, the port comes alive.  If I switch from the GS748Tv4 to the v5 we just got or even a spare cisco switch I had laying around, it works fine.
      The issue seems to reside between new model NICs and the v4 Prosafe.
      • JulienR's avatar
        JulienR
        Administrator
        Hi phrogboy264,
        New NICs model should works fine with the GS748Tv4.
        You can check the memory logs after trying to plug the new device and see if it is displaying any errors.
        You can send me the logs via private message and we will have a look into it.
        Thank you.
        Best Regards,
        Julien R.
ProSupport for Business
