Dantech-1
Jun 16, 2016Tutor
GS-108Tv2 Firmware upgrade hanging at 22% or less completed
I have tried previously to firmware upgrade my switch unsuccessfully. Tonight I was determined to give it another go. I did the following: - Used the recommended SCC (Smart Control Centre) soft...
- Jun 16, 2016
This worked - to firmware upgrade you should connect a LAN cable directly to the switch, do not plug in anything else and keep it off the network. Install the SCC software on the PC connected to the switch. Also ensure both the switch and PC are in the same subnet or the switch warns you and gives you chance to quit.
Problem solved - I first tried this months ago but gave up.
Dantech-1
Jun 16, 2016Tutor
JohnRo
Jun 17, 2016NETGEAR Employee Retired
Hello Dantech-1,
Thank you for sharing the solution. We appreciate your help!
Thanks,
