haef
Sep 10, 2018Aspirant
GS105E: cannot factory reset, update, or log in
I have a Prosafe Plus GS105E switch. firmware 1.02.04
It's been sitting on the shelf for a couple of months. I got it out to use it, and I cannot access it to configure it. The switch discov...
- Sep 19, 2018
What about using the ProSafe Plus Configuration utility (permitting you have a Windows system at hand) for discovery, then for access/factory reset/firmware update?
schumaku
Sep 19, 2018Guru - Experienced User
haef
Sep 19, 2018Aspirant
Thanks for the suggestion, but I tried that too. The Windows tool could see the switch but wouldn't allow resetting and so forth.
The whole thing is sort of moot now as I gave the switch to a local techie charity to play with. There's only so much messing with a $50 switch I'm going to do.
