AkeRolf
Jan 23, 2017Follower
GS105ev2 disable EEE mode
Is it possible to disable EEE mode or not? You can disable Power Saving Mode....does that mean that EEE i disabled!
- Jan 23, 2017
Hi AkeRolf,
Welcome to NETGER's Online Community!
Per my understanding of the User Manual, turning off Power Saving mode on GS105Ev2 system also turns off Short Cable, Link-Down and EEE Power saving features too on the same system.
However, you can still wait for further explanation from others.
I hope that helps.
Thanks
Evans-o
Jan 23, 2017NETGEAR Expert
Hi AkeRolf,
I hope that helps.
Thanks
- XavierLLJan 23, 2017NETGEAR Employee Retired
HI AkeRoff,
EvansO is right the Power Saving option disables the EEE
Hope that it helps
Xavier Lleixa
NETGEAR CBU PLM
- tomboisseauFeb 22, 2017Aspirant
I am very confused. I have looked and looked in the Prosafe Plus Configuaration Utility v2.3.20 and, inspite of the mention on page 39 of the ProSAFE Plus Utility User Manual, Nov 2016, when I go to "System > Management > Power Saving Mode", the is NO power saving mode option. The only thing that appears there is "Loop Detection". I'm using a GS105E-200NAS (aka GS105Ev2) What am I doing wrong?
Thanks,
Tom
