bugmenot2
Jul 03, 2016Apprentice
GS105PE - PoE pass through not working until hard reset
I have my GS105PE for some time now and from day 1 it had this wierd PoE problem. When I reboot the GS105PE, or the switch that is powering GS105PE reboots, I cant get PoE passthrough to work until ...
- Jul 04, 2016
Hi bugmenot2,
Since you have already tried two PSE switches already, it would be best that you open an online case with NETGEAR Support at anytime about your concern for further assistance.
DaneA
NETGEAR Community Team
DaneA
Jul 04, 2016NETGEAR Employee Retired
Hi bugmenot2,
I do not have an Ubiquiti ES-24-250W switch to replicate your concern. Kindly answer the questions below:
a. What is the current firmware version of the GS105PE?
b. Have you tried using other PSE switch(es) other than the Ubiquiti ES-24-250W switch to isolate the problem?
DaneA
bugmenot2
Jul 04, 2016Apprentice
Hi DaneA,
a. I am running V1.4.0.6. I updated last night.
b. I didnt try that before but I just tried with Dlink DES-1210-28P and same issue.
I also tried my other GS105PE but again same issue.
But I made progress I think. If I keep the GS105PE disconnected for 5mins, and then reconnect, the UAP-Pro also works.
Dont know if it was just luck, or GS105PE needs to discharge or something.
Still it is a flaw and I would like to resolve it as this would require me to run to each of my GS105PE switches and manually disconnect/connect them for PSE to work every time my main switch is updated/rebooted.
Thank you.
- DaneAJul 04, 2016NETGEAR Employee Retired
Hi bugmenot2,
DaneA
- kai01Jul 07, 2016Aspirant
same here, same problem now with 4 different GS105PE. See also support case # 27108350.
Guess there is some hardware issue with the device ? I observed this by time going worse...
Regards
Kai
btw tried all different available firmware 1.2.x / 1.3.x / 1.4.0.6 / ...
Thanks to bugmenot2 - at least a workaround for the devices not build into the wall...
Anyway to make this hardreset other then pressing the reset button for 10 seconds ?
- DaneAJul 11, 2016NETGEAR Employee Retired
Hi kai01,
May we know what happened to your online case you've opened with NETGEAR Support?
DaneANETGEAR Community Team
- Feb 22, 2022Retired_Member
