bugmenot2
Jul 03, 2016Apprentice
GS105PE - PoE pass through not working until hard reset
I have my GS105PE for some time now and from day 1 it had this wierd PoE problem. When I reboot the GS105PE, or the switch that is powering GS105PE reboots, I cant get PoE passthrough to work until ...
- Jul 04, 2016
Hi bugmenot2,
Since you have already tried two PSE switches already, it would be best that you open an online case with NETGEAR Support at anytime about your concern for further assistance.
DaneA
NETGEAR Community Team
Xelas
Aug 31, 2016Aspirant
Small addition - on port 5, here is the behavior when plugging in the cable form a PoE switch:
1) light turns orange instantly
2) After about 200 ms, the light turns green
3) After another 500-700 ms, the light turns back to orange.
Hope this helps.
DaneA
Sep 01, 2016NETGEAR Employee Retired
Hi Xelas,
Welcome to the community! :)
Have you tried to perform a factory reset on the GS105PE switch then check if same problem will occur? If yes and still same problem, I suggest you to open an online case with NETGEAR Support at anytime. Kindly state your concerns for further assistance.
DaneA
- Feb 22, 2022Retired_Member
