inky
Oct 14, 2016Guide
GS108Ev2 incorrect password after restoring configuration
I have 3 Netgear GS108Ev2 switches. All 3 units have firmware 1.00.12, and I'm using the Prosafe Utility v2.3.20 Recently I reconfigured the VLANs in my local netowrk, and after modifying the s...
- Oct 19, 2016
Suggestion added. It's here:
Thanks!
inky
Oct 17, 2016Guide
Minimal summary
Only upgrade firmware if you know you need to. Recovering old config files is a major hassle, if it's possible at all.
Discussion
I think I found out what happened.
(From GS108Ev2 firmware v1.00.12 release notes)
WARNING - Please make sure the version of the Prosafe Plus Utility installed on your PC is v2.2.24 or newer before upgrading the GS108Ev2 firmware. Older versions of the Plus Utility do not support the password encryption required by V1.00.10 firmware.
In my understanding, what this means is:
To restore old configurations, the switches must be downgraded to firmware v1.00.09 or older. Otherwise the unencrypted passwords of old firmware versions won't be correctly read by newer firmware versions from 1.00.10 onwards, so you will be locked out of the switch until you reset it to factory.
The Prosafe utility must be downgraded to v2.2.23 or older too, or it will try to encrypt the passwords and the older firmare versions won't be able to read them, since they expect them uncrypted.
I reiterate my suggestion to the developers: at least put a cleartext header in the config file, so the switch (or the user!) knows which firmware version saved it. If you want to make it really functional, have appropriate checks at load (restore) time, so old unencrypted passwords keep on working on new firmware versions.
DaneA
Oct 18, 2016NETGEAR Employee Retired
Hi inky,
About your suggestion, you may post it as a feature request in the Idea Exchange for Business here. Be reminded that adding kudos to the ideas will help as the development team will be reviewing the post that has the most kudos and it might be considered to be added on the future functionality of the product.
DaneA
NETGEAR Community Team
- inkyOct 19, 2016Guide
Thanks!
