mairo
Mar 21, 2016Aspirant
GS108Ev2 timeout
Hello, i try to get access to my GS108v2. I use the Software Prosafe Plus Utility 2.3.5. OS: Windows 7 (with firewall disabled). All Computers/Router and the switch are in the same subnet. We...
- Mar 21, 2016
Hi mairo,
Welcome to the community! :)
Kindly try these steps below:
a. Disconnect the the GS108Ev2 from the existing network.
b. Reset the GS108Ev2 back to factory default settings.
c. Connect a PC directly to any LAN port of the GS108Ev2. Make the ProSAFE Plus Configuration Utility v2.3.5 is installed on the PC.
d. Set a static IP address that is within the range of the default IP address of the GS108Ev2 which is 192.168.0.239. You may double-check it by opening command prompt on the PC then check if you will get replies if you ping the default IP address of the GS108Ev2.
e. Open the ProSAFE Plus Configuration Utility v2.3.5 then check if it discovers the GS108Ev2.
f. Check if you will be able to manage the GS108Ev2 just fine using the ProSAFE Plus Configuration Utility v2.3.5 while the PC is still directly connected to it.
Are you still getting the same error message after doing the steps above?
DaneA
NETGEAR Community Team
mairo
Mar 22, 2016Aspirant
Thanks! It woks now! Perfect!
JohnRo
Mar 22, 2016NETGEAR Employee Retired
Hello mairo,
Glad to know that you have it working! If DaneA's post helped you fix the issue, please mark it as a solution this will help other members of the community when they experience the same issue.
Thanks!
