Ra1n
Aug 13, 2015Follower
GS108Ev3 Cannot set VLAN for management interface
I just purchased a GS108Ev3 because I needed some simple VLAN segregation for a small group of machines "down the hall" from my core networking equipment. The switch works great, though there is one ...
- Jan 07, 2016
Hi chulio,
Welcome to the community! :)
I think this is by design and not a limitation of the GS108Ev3 since its category is a ProSAFE Plus Gigabit switch which adds a configuration layer to the standard unmanaged switch.
For the alternative, I recommend you the GS108Tv2 or GS110TP switches.To know more about the GS108Tv2 and GS110TP switches, check these links below:
GS108Tv2 and GS110TP Product FAQs
DaneA
NETGEAR Community Team
JohnRo
Aug 13, 2015NETGEAR Employee Retired
Hello Ra1n,
It is true that you cannot change the default management VLAN for this model, the switch is only a Prosafe Plus switch and is intended for more simple networks. What you can do is to post a topic on our Idea Exchange Board so that our engineers can see if they will consider adding this feature on future firmware releases. Make sure you hit the kudos(like) button, if it gets enough kudos from users then it can be considered.
Hope that helps, if you have questions feel free to ask.
Thanks,
chulio
Jan 07, 2016Aspirant
Same issue, for my 3x GS108e v3 it doesn't even work for VLAN 1 !
(if a second or third VLAN are tagged on the same port), no GUI management possible.
It seems the GS108e takes the VLAN with the fastest DHCP server and then you get an IP you can use for GUI management.
Is there a solution in the meantime for the GS108e ?
Or which alternative product provides that functionality ?
Thanks a lot in advance,
Best chulio
- DaneAJan 07, 2016NETGEAR Employee Retired
Hi chulio,
DaneA
NETGEAR Community Team- waheulerMay 02, 2016Initiate
I am very disappointed that this handicapping of configuration is considered a design decision or a "feature" as referred to earlier. I can't help but feel it is merely a cop-out to encourage the purchase of a higher end unit. Even though most other smart switches at this level have the configuration option that is missing here.
- JohnRoMay 02, 2016NETGEAR Employee Retired
Hello waheuler,
I'm sorry to hear about your disappointment on the product. In defense to that, just like what we have mentioned on our previous replies this is a single step from unmanaged switches. It is intended for networks with little or no management needed. These switches have different chipsets and memory that is why we cannot fit everything on this unit.
Thanks,
