Ra1n
Aug 13, 2015Follower
GS108Ev3 Cannot set VLAN for management interface
I just purchased a GS108Ev3 because I needed some simple VLAN segregation for a small group of machines "down the hall" from my core networking equipment. The switch works great, though there is one ...
- Jan 07, 2016
Hi chulio,
Welcome to the community! :)
I think this is by design and not a limitation of the GS108Ev3 since its category is a ProSAFE Plus Gigabit switch which adds a configuration layer to the standard unmanaged switch.
For the alternative, I recommend you the GS108Tv2 or GS110TP switches.To know more about the GS108Tv2 and GS110TP switches, check these links below:
GS108Tv2 and GS110TP Product FAQs
DaneA
NETGEAR Community Team
gmerb
Feb 20, 2017Tutor
Same problem on JGS524PE.
This "feature" is mandatory, VLAN is useless if you can't secure your installation !
Idem, back to HP / Cisco ...
DaneA
Feb 20, 2017NETGEAR Employee Retired
This is by design and not a limitation of the GS108Ev3 switch since its category is a ProSAFE Plus Gigabit switch which adds a configuration layer to the standard unmanaged switch.
Since you find the feature to be mandatory on this switch model, I suggest you to kindly post your concern as a feature request on the Idea Exchange Board for Business here. In this way, the development team can see what feature does users wanted to be added to the functionality of the product. Be reminded that the more kudos given by community members to your feature request will help as the development team will be reviewing the post that has the most kudos and will be considered.
DaneA
- Apr 12, 2023Retired_Member
