Badnewsbc
May 26, 2023Aspirant
GS108LP Broken power
Hello, I am an amateur tinker and wanted to try fixing a broken power port in my GS108LP switch. The power port has 3 tabs soldered to the motherboard. However 1 of those tabs broke when the switch dr...
May 27, 2023Guru - Experienced User
If you're not worried about warranty, I've direct wired the power supply into a motherboard before on a broken power port. Worked fine.
- BadnewsbcJun 12, 2023Aspirant
I can't say I am experienced in setting that up. Is there a good guide or maybe a website I can use to buy the individual part?
- schumakuJun 12, 2023Guru - Experienced User
Most users here have never opened and disassembled their network devices. Even if the outside looks similar, the soldered on power ports can be different.
Start with posting some good photos of the broken part and it's location on the PCB.
Not many people (including Netgear reps) - virtually nobody - has access to the manufacturer or OEM parts list.
