rfcat_vk
Jul 26, 2022Aspirant
GS108Pe v3 interrupted during firmware upgrade and no longer provides access to GUI
Hi folks,
I have looked at a number of threads on a similar subject and sort of received an answer.
1/. the device still works as an unmanaged switch
2/. reset to factory defaults does not work
3/. seems to be locked into an IP address that tracert, but not pings
4/. not sure when I purchased the device, so probably have to consider it partially bricked.
5/. the Netgear switch identification application cannot find the switch
Thoughts and suggestions please?
Ian
With the device being in bootloader mode, the default 192.168.0.239/24 can be in place - so plan a computer in that same subnet.
Hope you have a Windows system at hand. Head to the GS108PEv3 Firmware and Download Pages and install and run the (old, hardcore, ...) ProSAFE Plus Configuration Utility v2.7.8 - this might help to re-install the firmware again.
