DominikHoffmann's avatar
Feb 19, 2023
GS108Tv2 management interface exposed on what VLAN?
On my GS108Tv2 I have changed the PVID of all ports to VLAN ID 101. However, in the VLAN Membership configuration I have all ports as untagged, except for Port 2, which is tagged. This is because the GS108Tv2 is downstream from a switch that uses VLAN ID 101. Untagged frames on Port 1 and 3–8 connect to the router’s LAN interface
The LAN interface has the address 192.168.1.1 and a DHCP server running that serves addresses in the 192.168.1.0/24 subnet. I assigned the IP address 192.168.1.106 to the GS108Tv2 before I made the PVID change described above. Before the PVID switch it was reachable.
Now I can no longer reach the management interface of the switch. How can I force that interface to be exposed to the untagged 192.168.1.0/24 subnet?
1 Reply
  • schumaku's avatar
    schumaku
    The management VLAN must be assigned to the same VLAN where you bring these VLAN in, being on a tagged trunk port, being on an access port assigned to a certain VLAN, like the VLAN ID 101 in your example.
ProSupport for Business
