kgoode517
Mar 19, 2022Tutor
GS108Tv2 Switch Does Not Have Internet Access
I am unable to connect to the internet from any computer that has an ethernet connection to the switch I am not able to access the admin portal from the default address of 192.168.0.239. I have reset...
- Mar 21, 2022The switch is powered normally with its power cord leds show normal double green lights for full network speed. I have resolved the issue. I was only resetting the switch with the reset button. I did not notice on the front right there was a factory reset button separate from the reset button so it was retaining its previous settings as I bought it used. When I reset with the reset button it just retains those settings. It is working great now!
kgoode517
Mar 20, 2022Tutor
Hi Dane,
Thanks for taking a look. Yes I have normal connection with the router and an ethernet connection to my PC. I cannot find an ip for the switch I never assigned one so I would have assumed that it would have assigned one via DHCP and been able to see it on the router but I can’t. I also attempted to find it on the default 192.168.0.239 but it does not appear even when resetting the switch. I don’t believe I will be able to see the firmware version without being able to access the admin page unless you have another suggestion for doing so.
schumaku
Mar 21, 2022Guru - Experienced User
How is the switch powered?
The power LED is on?
The link LED (on the GS108TVs both for a GbE link) shows the correct link speed?
- kgoode517Mar 21, 2022TutorThe switch is powered normally with its power cord leds show normal double green lights for full network speed. I have resolved the issue. I was only resetting the switch with the reset button. I did not notice on the front right there was a factory reset button separate from the reset button so it was retaining its previous settings as I bought it used. When I reset with the reset button it just retains those settings. It is working great now!
- schumakuMar 21, 2022Guru - Experienced User
Of course, random VLAN and port configs are easily prohibiting the usage as a plain L2 switch.
