buckZor's avatar
buckZor
Guide
Mar 20, 2014
GS108Tv2 .. unreachable
Brought home a new GS108Tv2. Wired it up, was passing packets fine, hopped on my Juniper SRX210H (my DHCP server) and saw the IP assigned it by DHCP. Got into the device fine. Changed the device na...
  • buckZor's avatar
    Mar 21, 2014
    I was able to resolve my own problem with this one. I must say, browsing this forum there doesn't seem to be many responses, maybe it's completely user based with no Netgear involvement? Pity, don't think I'd have bought the switch had I seen this prior.
    Regardless, on to the fix. I run all Macs in my house, when I installed Smart Control Center on my Parallels virtual, it scanned the network and found zero devices. I dug a little deeper and discovered that the adapter address SCC was using was a strange 10.0.x.x. Then checked the IP config of the virt and it too had the 10.0.x.x address. Checked the Parallel settings for the virtual and for network it was using "Shared Network". I changed it to bind directly to my Thunderbolt Ethernet and wallah, it got a 192.168.x.x address on my local area network.
    NOW.. SCC found the switch on a network discovery. Interestingly it was ignoring my DHCP and using the factory default IP of 192.168.0.239. 192.168.0.x is not my network, but magically SCC was able to access it, I changed the IP address to what I wanted on my local network and wallah, it was back to working.
    Hope this helps someone else, this switch is a strange mix of poop and awesome. Don't know if I'll keep it or not. I can't even determine how to completely disable QOS/COS. I'd ask here but nobody would answer. *shrug* :rolleyes:
ProSupport for Business
