thatguymoon
Mar 25, 2026Aspirant
GS110EMX: 10G ports throttle uploads to 250-300 Mbps
I've been going back and forth with Netgear support for over a week about this and I'm honestly at a loss. I'm hoping someone here can tell me if I'm crazy or if what they're telling me doesn't make ...
thatguymoon
Mar 26, 2026Aspirant
Thanks — QoS rate limits are confirmed not set, factory reset has been done, and I'm using Cat6A cables. My iPerf results at 9.4 Gbps locally confirm the cables and ports are working fine. Sounds like you ran into the same core issue and solved it by adding a 10G switch upstream. I shouldn't need a $250 workaround for a switch that's supposed to handle mixed speeds though.
Mar 26, 2026Guru - Experienced User
thatguymoon wrote:I shouldn't need a $250 workaround for a switch that's supposed to handle mixed speeds though.
FWIW, I agree.
