egnlsn
Sep 20, 2026Aspirant
GS305E and VLANs
I'm trying to get a GS305E switch configured for VLANs. The VLANs at the port on the router to which this switch is connected are 5 (main one) and 7. I need to configure this switch so that VLAN 7 ...
egnlsn
Sep 21, 2026Aspirant
Thanks for the suggestions. Managing it was a want, not a need. Considering that everything plugged into it will never need anything other than VLAN 7, I decided to just reset it and use it as a dumb switch.
